This page contains information about the V-Ray Softbox Texture.
V-Ray Softbox is a procedural texture that can be used with a V-Ray Light to simulate the illumination coming from a Soft Box light source.
width10%
width40%
width40%
width10%
UI Paths
width33%
||mat Network|| > V-Ray > Texture: ProceduralTexture > V-Ray Soft BoxSoftbox
width33%
||out Network|| > V-Ray Render Elements node > V-Ray > Texture: ProceduralTexture > V-Ray Soft Box Softbox
width33%
Node
width50%
The TexSoftbox node provides inputs for controlling various texture properties. They correspond to parameters in the section below.
width5%
width45%
Image Modified
width50%
Use Base Texture
 – When enabled,
the Base Texture
 is used instead of
the Base Color.
Base Texture
 – Specifies a texture to use as a base.
Base Color
 – Specifies a color to use as a base.
Base Multiplier
 – A multiplier for the brightness of the texture.
Base Gamma
 – A gamma correction that is applied to the texture.
Use Base
Tint – When enabled, the color in
the Base Texture
 parameter is multiplied by
the Base Tint
Color parameter.
Tint Color
 – Specifies a color to tint the light.
Tint Strength
 – A multiplier that controls how strong the effect of
the Base Tint Color
 parameter is.
width5%
width45%
Image Added
Radial Vignette
width50%
Enable – Enables the radial gradient.
Radial Vignette Flip – When enabled, reverses the radial gradient.
width5%
width45%
Image Added
Vertical Vignette
width50%
Enable – Enables the vertical gradient.
V Vignette Flip
 – When enabled, reverses the vertical gradient.
width5%
width45%
Image Added
Horizontal Vignette
width50%
Enable
 – Enables the horizontal gradient.
U Vignette Flip – When enabled, reverses the horizontal gradient.
width5%
width45%
Image Added
Frame Vignette
width50%
Enable
 – Enables the frame gradient.
Frame Vignette Flip
 – When enabled, reverses the frame gradient.
Use Frame Tint
 – Enables the frame tint.
Tint
Color – Specifies a color to tint the frame.
Tint Strength
 – A multiplier that controls how strong of an effect the
 Tint Color
 has.
Enable Frame
Noise – Enables frame noise.
Noise Amount
 – Specifies the amount of frame noise.
Noise Size
 – Specifies the scale of the frame noise.
Noise Phase
 – Specifies the phase of the frame noise.
Fractal Noise
 – When enabled, generates a fractal noise pattern.
Fractal Levels
 – When Fractal Noise
 is enabled, this controls the number of fractal iterations.
width5%
width45%
Image Added
Spots
width50%
Enable – Enables or disables the hot/dark spot.
Spots Mode – Specifies how the hot/dark spot is applied.
Hot Spot – Color is added to the texture, adding brightness and creating a hot spot.
Dark Spot
– Color is subtracted from the texture, removing brightness and creating a dark spot.
Softness – Controls the rate at which the hot spot fades out.
Inner Radius – Specifies the inner radius where the hot spot begins to fade out as a fraction of the texture size.
Outer Radius – Specifies the outer radius where the hot spot ends as a fraction of the texture size.
Spots Multiplier – A multiplier for the brightness of the hot/dark spot.
U/V Offset – Controls the position of the spots along the U or V axis.
U/V Tiling – When enabled, controls the tiling of the spots along the U or V axis.
Spots Tint On – Enables the tint color for the spots.
Spots Tint Color – When enabled, controls the color of the hot spot.
Spots Tint Strength – A multiplier that controls how strong the strength of the Tint Color parameter.
width5%
width45%
Image Added
Color Tweaks
Image Removed
width50%
Default Color – Specifies the color when there are no valid UVW coordinates.
Mult – Specifies a strength multiplier for the texture color.
Offset – Color corrects the texture by adding the the RGB color values specified here to the RGB color values in the texture.
Invert
 – When enabled, inverts the resulting texture color.
width5%
width45%
Image Added
Alpha Tweaks
Image Removed
width50%
Source – Specifies where the alpha channel is drawn from.
Alpha – Alpha channel is drawn from the texture.
Color
– Alpha is generated from pixel intensity.
Opaque – Alpha channel is fully opaque.
Use – Differentiate between textures exported from different applications. You can choose between Color Intensity (3ds Max) and Color Luminance (Maya).
Mult
 – Specifies a multiplier for the texture alpha.
Offset
 – Specifies an additional offset for the texture alpha.
Invert
 – When enabled
and Invert
 from Color
Tweaks is also enabled, the resulting texture alpha is inverted as well.
Placement
width5%
width45%
Image Added
Placement
width50%
Placement Type
 – Specifies the way the valid portion of the texture is applied.
Full – Uses the full valid portion of the texture.
Crop – Allows the user to specify a section of the texture using the parameters below.
Place – Allows the user to specify a section of the texture and how to place it using the parameters below.
U
 – Specifies the U coordinate of the valid texture sector.
V
 – Specifies the V coordinate of the valid texture sector.
W
 – Specifies the width of the valid texture sector.
H
 – Specifies the height of the valid texture sector.
Jitter
 – Controls the amount of random placement variation.
Tile U
 – Enables horizontal tiling.
Tile V
 – Enables vertical tiling.
width5%
width45%
Image Added
UV Noise
Image Removed
width50%
Enabled – Enables noise for the texture.
Amount
 – Specifies the amount of noise to add to the texture.
Levels
 – Specifies the amount of noise iterations.
 – Controls the scale of the noise.
Animated
 – Enables the noise to be animated.
Phase
 – Controls the noise phase.
width5%
width45%
Image Added
Gradients
The Gradients options allow the user to blend gradient textures on top of the V-Ray Softbox texture. You can add a gradient in the U and V direction and place a frame - which is a gradient in both directions.
