width5%
width45%
||mat Network|| > V-Ray > Texture: File Textures > V-Ray Lut
width45%
||out Network|| > V-Ray Render Elements node > V-Ray > Texture: FileTexture > V-Ray Lut
width5%
Node
width50%
The V-Ray TexLut node provides inputs that correspond to the parameters in the section below.
width5%
width45%
Image Modified
width
50%
Base
Map – A slot to load the map that you want the LUT to be applied to.
LUT
File – Specifies the location of the look up table.
Convert to Log Space before applying
LUT – Converts the Base map to a logarithmic color space before applying the look up table.
width5%
width45%
Image Added
