For example, BRDFGlass can be created and assigned to an object by itself, but Mtl2Sided will expect other BRDF or Mtl plugins to be specified as its front and back materials.
UI Expand
titleUI Path: ||Material Editor window|| > Material/Map Browser...
 > Materials
 > V-Ray
 > VRayPluginNodeMtl
width20%
width60%
Image Modified
width20%
General parameters
width60%
Plugin - Choose from the available material plugins that come with the V-Ray installation.
width5%
width35%
Image Added
Plugin nodes parameters
Details on plugin nodes from plugins are available with the plgparams.exe tool that comes with the V-Ray installation. For additional information, see the Exploring Plugin Parameters in CMD page.
