This page provides information on batch rendering with V-Ray for Maya.
Floatingpagetoc |
V-Ray can take advantage of Maya's ability to render scenes directly from a command line, freeing up the resources that would normally be used up by the application and its GUI. Also, this process allows multiple scenes to be grouped together and rendered one after the other, without having to load scenes in between renders. For more general information on rendering with Maya from a command line, please see the Autodesk Maya documentation. Flags can be added to the execution of the command to customize the way V-Ray renders the desired scene. V-Ray will respect common Maya flags as well as a host of V-Ray specific flags detailed on this page.
