width45%
V-Ray Layered texture offers stacking of multiple textures on top of each other in order to mix their output. The result of each layer depends on the blending mode with the next layer in the stack. You can also use a mask to control what parts of the texture will appear in the render.
Note that the "upper" layer is the one with higher number. That is, Layer[0] is the bottom layer.
UI Text Box
typetip
When adding a new layer, it is placed on the bottom of the stack. Layers are applied from the top to the bottom.
width5%
width50%
UI Paths
  >  ||Create Render Node|| > VRay section > 2D Textures > VRay Layered Tex
UI Expand
titleUI Path:
width50%
||Hypershade||
> Create panel > VRay section > 2D Textures
Image Added
> VRay Layered Tex
width50%
Add New Item button – Adds a layer in the stack.
