This page contains information about the V-Ray Rock Texture.
width50%
The V-Ray Rock Texture generates a procedural rock pattern using two colors or texture maps.
width5%
width45%
UI Paths
width33%
||mat Network|| > V-Ray > Texture: Procedural > V-Ray Rock
width33%
||out Network|| > V-Ray Render Elements node > V-Ray > Texture: Procedural > V-Ray Rock
width33%
Node
width50%
The TexRock node provides inputs for controlling various texture properties. They correspond to parameters in the section below.
width5%
width45%
width50%
Color 1 – Controls the first of the two colors used by the V-ray Rock procedural.
Color 2 – Controls the second of the two colors used by the V-ray Rock procedural.
Mix Ratio – Controls the mix between Color 1 and Color 2. For more details, please see the Mix Ratio example below.
Grain Size – Controls the size of the fine grain features. For more details, please see the Grain Size example below.
Diffusion – Lower values make the resulting texture sharper, while higher values blur the texture details moreFor more details, please see the Diffusion example below.
Wrap – Enables wrapping for the texture.
width5%
width45%
Color Tweaks
width50%
Default Color – Specifies the color when there are no valid UVW coordinates.
Mult – Specifies a strength multiplier for the texture color.
Offset – Color corrects the texture by adding the the RGB color values specified here to the RGB color values in the texture.
Invert – When enabled, inverts the resulting texture color.
width5%
width45%
Alpha Tweaks
width50%
Source – Specifies where the alpha channel is drawn from.
Alpha – Alpha channel is drawn from the texture.
Color
– Alpha is generated from pixel intensity.
Opaque
– Alpha channel is fully opaque.
Use – Differentiate between textures exported from different applications. You can choose between Color Intensity (3ds Max) and Color Luminance (Maya).
Mult – Specifies a multiplier for the texture alpha.
Offset – Specifies an additional offset for the texture alpha.
Invert – When enabled and Invert from Color Tweaks is also enabled, the resulting texture alpha is inverted as well.
width5%
width45%
Placement
width50%
Placement Type – Specifies the way the valid portion of the texture is applied.
Full – Uses the full valid portion of the texture.
Crop – Allows the user to specify a section of the texture using the parameters below.
Place – Allows the user to specify a section of the texture and how to place it using the parameters below.
U – Specifies the U coordinate of the valid texture sector.
V – Spcifies the V coordinate of the valid texture sector.
W – Specifies the width of the valid texture sector.
H – Specifies the height of the valid texture sector.
Jitter – Controls the amount of random placement variation.
Tile U – Enables horizontal tiling.
Tile V – Enables vertical tiling.
width5%
width45%
UV Noise
width50%
Enabled – Enables noise for the texture.
Amount – Specifies the amount of noise to add to the texture.
Levels – Specifies the amount of noise iterations.
Size – Controls the scale of the noise.
Animated – Enables the noise to be animated.
Phase – Controls the noise phase.
width5%
width45%
Anchor
exampleGrainSize
exampleGrainSize
Example: Grain Size
width25%
width50%
Image slider
Panel
borderStylenone
Grain Size: 0.01
Panel
borderStylenone
Grain Size: 0.05
Panel
borderStylenone
Grain Size: 0.1
width30%
width25%
Anchor
exampleDiffusion
exampleDiffusion
Anchor
exampleMixRatio
exampleMixRatio
width5%
width45%
Image slider
Example: Diffusion
Panel
borderStylenone
Diffusion: 0.1
Panel
borderStylenone
Diffusion: 1.0
Panel
borderStylenone
Diffusion: 2.0
width45%
Example: Mix Ratio
Image slider
Panel
borderStylenone
Mix Ratio: 0.1
Panel
borderStylenone
Mix Ratio: 0.5
Panel
borderStylenone
Mix Ratio: 0.9
width5%
Fancy Bullets
typecircle
  • If V-Ray Rock textures are combined, diffusion can be used to provide a large detail coloring in one instance of V-Ray Rock texture and finer details provided with another. If black and white values are used then this could be a great way to generate realistic bump maps.
