The VRayUserInteger texture allows the user to read and return a single integer value from the User Attributes of the currently shaded object as a result. This can be useful if the same material or texture is applied to several objects in the scene, but you want to control some of its properties with User-Defined properties.
UI Expand
titleUI Paths
||Hypershade|| > Create panel > VRay section > Utilities
width10%
width40%
||Hypershade||
 >  ||Create Render Node|| > VRay section > Utilities > VRay User Integer
> Create panel > VRay section > Utilities > VRay User Integer
width40%
Image Added
width10%
width
60%
User attribute name – Specifies the name of the user attribute that is looked up and returned from this utility node.
Default value – Specifies the value to return if the user attribute is not found on the shaded object.
Required format for attribute value – Displays possible formats for the attribute in the V-Ray User Attributes string assigned to the object, and what is rendered as a result.
width5%
width35%
Image Added
