The Background Render Element includes just the background as set in the scene, with the rest of the image rendered as black. floatingpagetoc
Section | |||||||||||||||
UI Path
||Render Settings window|| > Render Elements tab > Background
Attributes
Section |
The parameters for this render element appear in the Attribute Editor under Extra V-Ray Attributes. |
Common Uses
The Background Render Element is primarily used for layering the Beauty element (or combined render elements) on top of the background image. The Alpha channel can be used to create a matte for such a composite. In the following example the atmosphere and depth of field have been turned off for the sake of clarity.
