This page gives an overview of the Global Illumination render element and explains how it is used in compositing.
Floatingpagetoc |
Section | |||||||||||||||
UI Path
||Render Settings window|| > Render Elements tab > GI
Attributes
Section |
The parameters for this render element appear in the Attribute Editor under Extra V-Ray Attributes. |
Common Uses
The Global Illumination Render Element is useful for changing the appearance of Indirect lighting after rendering, using a compositing or image editing software. Below are a couple of examples of its use.
