Section | |||||||||||||||
UI Path
||Render Settings window|| > Render Elements tab > Multi Matte ID
Multimatte ID Render Element Set up Procedure
Here's the workflow for setting up and using the Multi Matte ID Render Element:
Select the material in the Hypershade that a Multi Matte ID Render Element is needed for.
Column | ||
Column | ||
width | 33% |
