This page gives an overview of the Raw Global Illumination render element and how it may be used in compositing.
floatingpagetoc
OverviewOverview
Section | |||||||||||||||
UI Text Box | ||
This raw render element must be rendered along with the Global Illumination element (vrayRE_Gl) for proper results. |
||Render Settings window|| > Render Elements tab > Raw GI
Attributes
Section |
The parameters for this render element appear in the Attribute Editor under Extra V-Ray Attributes. |
Common uses
Once the scene is rendered, the Raw Global Illumination Render Element is useful for changing the appearance of indirect lighting in a compositing or image editing application. Below are examples of its use.
Fancy Bullets | ||
