This page gives an overview of the Raw Global Illumination render element and how it may be used in compositing.
width62%
The Raw Global Illumination Render Element stores how much indirect lighting (reflected diffuse light) is received by surfaces in the scene. This raw element is useful for fine-tuning indirect lighting in the compositing process.
The vrayREThe vrayRE_Raw_GI pass is untouched by the diffuse colors of the scene and represents the pure indirect lighting contribution. You can use this raw element to reconstitute the vrayRE_GI by multiplying the vrayRE_Raw_GI with the vrayRE_Diffuse .
UI Text Box
typenote
This raw render element must be rendered along with the Global Illumination element (vrayRE_Gl) for proper results.
width5%
width33%
UI Path
||Render Settings window|| > Render Elements tab > Raw GI
