This page gives some basic details about the Raw Shadow render element and explains how it is used.
Floatingpagetoc |
Section | |||||||||||||||
UI Path
||Render Settings window|| > Render Elements tab > Raw Shadow
Attributes
Section | |
Common Uses
The Raw Shadows Render Element is useful for changing the appearance of shadowed areas after rendering in a compositing or image editing application. Below is an example of its use, where the Raw Shadows are added (plus) with the vrayRE_Raw_Light pass.
Fancy Bullets | ||
