This page gives some basic details about the Refraction Filter Render Element and how it is used in compositing.
Floatingpagetoc |
Section | |||||||||||||||||||||||||||||
UI Path
||Render Settings window|| > Render Elements tab > Refraction Filter
Attributes
Section |
The parameters for this render element appear in the Attribute Editor under Extra V-Ray Attributes. |
Common Uses
The Refraction Filter Render Element is useful for changing the appearance of refractive elements after rendering, using a compositing or image editing application. Below are examples of possible uses.
Fancy Bullets | ||
