Underlying Compositing Equation
vrayRE_Raw_Shadow
x vrayRE_Diffuse = vrayRE_Shadow
Fancy Bullets
typecircle
  • The vrayRE_Shadow pass can be both added and subtracted with the final beauty comp at a composite level without rerendering.
  • Shadows can be color-corrected using the vrayRE_Shadow element.
  • When rendering with V-Ray GPU CUDA, the Shadow Render Element is incompatible with Adaptive Lights and may render incorrectly if used together.
