This page gives an overview of the Specular Render Element and explains how it is used.
Floatingpagetoc
width50%62%
The Specular Render Element isolates the reflected light in the scene. This render element is an image that stores specular reflection (highlight) information calculated from the material's reflection value in the scene. Specular reflection is defined as the reflection of light from a surface in a single particular reflection, as opposed to a diffuse reflection which is reflected at many angles.
The brighter the area, the more highlight reflection the object exhibits in the render. Specular highlights will be colored if the Reflection Color parameter of a material is colored.
width5%
width45%33%
Image Modified
UI Path
||Render Settings window|| > Render Elements tab > Specular
Attributes
width
62%
Enabled
 – When checked, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix
 – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.specular.vrimg).
Apply color mapping – Applies the color mapping options specified in
the Color mapping
 rollout of the
 VRay tab
 in the Render Settings window to this render element. This option is enabled by default.
Denoise – Enables the render element's denoising, if Denoiser render element is present.
width5%
width33%
Image Added
Evaluating the Specular Render Element
