This page provides details on the V-Ray Toon Render Element.
OverviewOverview
Section | |||||||||||||||
UI Path
||Render Settings window|| > Render Elements tab > Toon
Attributes
Section | |||||
Common Uses
The V-Ray Toon Render Element is useful for changing the appearance of a render in a compositing or image editing application. The vrayRE_Toon pass holds a mask for the toon outlines (the toon color is not present in it).
It has an option to invert its output so instead of white lines on a black background, we can get the opposite. It also supports opacity set from the toon effect.
Fancy Bullets | ||
