The Maya Render Settings window hosts many V-Ray settings for both V-Ray and IPR. Depending on which render mode you are using, the available settings will change. For more information about choosing and setting up your renderer, please see the Selecting a Renderer section section on the Installation and Licensing page.
UI Expand
titleUI Path: || Windows menu || > Rendering Editors > Render Settings
width10%
width35%
Image Modified
width10%
width35%
||Maya status bar|| > Display render settings button
Image Modified
width10%
