changes.mady.by.user Unknown User (zheni.metodieva)
Saved on May 12, 2020
changes.mady.by.user Kristin Ivanova
Saved on May 15, 2020
||Render Settings window|| > Render Elements tab > BumpNormals
Enabled – When checked, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.bumpnormals.vrimg).
Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler rollout in the VRay tab of the Render Settings.
Image Added
