||Render Settings window|| > Render Elements tab > Multi Matte ID
Attributes
Section | ||||||||||||||||||||||||
Multimatte ID Render Element Set up Procedure
Here's the workflow for setting up and using the Multi Matte ID Render Element:
Common Uses
A typical usage of this render element, is to use the colors produced in the Multi Matte ID to produce a mask or alpha channel in post production that covers everything with that Multi Matte ID.
