||Render Settings window|| > Render Elements tab > Raw Shadow
Attributes
Section | |||||||||||||||||||
Common Uses
The Raw Shadows Render Element is useful for changing the appearance of shadowed areas after rendering in a compositing or image editing application. Below is an example of its use, where the Raw Shadows are added (plus) with the vrayRE_Raw_Light pass.
