In the example below, the VRayPluginNodeMtl is used with the BRDFMultiBump material. Multiple bump maps with different bump amounts can be fed in the plugin which is unique.
Image RemovedImage Removed
width5%
width45%
Image Added
width45%
Image Added
width5%
