UI Text Box
typeinfo
Starting with V-Ray 5.0, when user attributes are used in the beginning of a file path, V-Ray treats the path as absolute. For example, if a file node loads a texture from <userAttribute>/texture.png, the path is treated as absolute and the Maya project path will no longer be prepended.
UI Expand
titleUI Path: ||Select mesh|| > Attribute Editor > Attributes menu > VRay > User Attributes
