width62%
The Background Render Element stores an image of the texture used in the background behind geometry in a scene as seen from the camera. Geometry that blocks the background image renders as black.
This render element interprets a background texture, such as the texture set in the Environment Overrides, as a background.
Other types of manually created backgrounds, such as a plane, mapped with a texture set outside a window, will not interpreted to be a "background" for the purposes of this render element.
width5%
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Atmospheric Effects > Background
width
33%
 Image Removed
UI Path
50%
button||
> Render Elements tab > Background
Image Added
width50%
Render (menu) > Render Settings > Background
Image Added
width5%
width33%
 Image Added
Attributes
width62%
Enabled – When enabled, the render element appears in the V-Ray frame buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.background.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color mapping rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
width5%
width33%
