column
width62%
The Raw Global Illumination Render Element stores how much indirect lighting (reflected diffuse light) is received by surfaces in the scene. This raw element is useful for fine-tuning indirect lighting in the compositing process.
The vrayRE_Raw_GI pass is untouched by the diffuse colors of the scene and represents the pure indirect lighting contribution. You can use this raw element to reconstitute the vrayRE_GI by multiplying the vrayRE_Raw_GI with the vrayRE_Diffuse .
UI Text Box
typenote
This raw render element must be rendered along with the Global Illumination element (vrayRE_Gl) for proper results.
UI Expand
width5%
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Raw GI
width
33%
Image Removed
UI Path
45%
button||
Image Added
width10%
width45%
Render (menu) > Render Settings > Raw GI
Image Added
width5%
width33%
Image Added
Attributes
width62%
Enabled – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.rawGI.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color mapping rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
Denoise – Enables the render element's denoising, provided the Denoiser render element is present
width5%
width33%
