column
width62%
The Raw Refraction Filter Render Element is similar to the Refraction Filter Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of refraction.
UI Text Box
typenote
 To properly calculate the Raw Refraction Filter Render Element, the Refraction Render Element must also be added to the list of render elements being calculated during the rendering process to properly determine all the refraction information in the scene.
UI Expand
width5%
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Raw Refraction
width
33%
Image Removed
UI Path
45%
button||
> Render Elements tab > Raw Refraction Filter
Image Added
width10%
width45%
Render (menu) > Render Settings > Raw Refraction Filter
Image Added
width5%
width33%
Image Added
width62%
Enabled – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.rawRefractionFilter.vrimg).
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
width5%
width33%
