The Raw Refraction Filter Render Element is similar to the Refraction Filter Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of refraction.
UI Text Box
type
note
To properly calculate the Raw Refraction Filter Render Element, the Refraction Render Element must also be added to the list of render elements being calculated during the rendering process to properly determine all the refraction information in the scene.
UI Expand
title
UI Path: ||Display Render Settings button|| > Render Elements tab > Raw Refraction
width
45%
||Display Render Settings button||> Render Elements tab > Raw Refraction Filter
width
10%
width
45%
Render (menu) > Render Settings > Raw Refraction Filter
To use render elements, select from the Available render elements column and click the Add button to add the passes you wish to generate at render time. When you render the scene, the added render elements listed in the column on the right, will also render, which can be viewed from the VFB window's channel drop-down menu.
For more information on the parameters on this dialog, see the Render Elements tab page.
width
5%
width
33%
width
62%
Enabled – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.rawRefractionFilter.vrimg).
