width62%
The Raw Refraction Filter Render Element is similar to the Refraction Filter Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of refraction.
UI Text Box
typenote
To properly calculate the Raw Refraction Filter Render Element, the Refraction Render Element must also be added to the list of render elements being calculated during the rendering process to properly determine all the refraction information in the scene.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Raw Refraction
width45%
||Display Render Settings button|| > Render Elements tab > Raw Refraction Filter
width10%
width45%
Render (menu) > Render Settings > Raw Refraction Filter
width5%
width33%
