width62%
The Raw Shadow Render Element stores information about cast shadows calculated from the lighting in the scene.  It It is a "reverse" image in the sense that white areas indicate shadows while black areas indicate no shadow.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Raw Shadow
width45%
width10%
width45%
Render (menu) > Render Settings > Raw Shadow
width5%
width33%
Attributes
width62%
Enabled – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.rawShadow.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color Mapping rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
width5%
width33%
