width62%
The Raw Shadow Render Element stores information about cast shadows calculated from the lighting in the scene. It is a "reverse" image in the sense that white areas indicate shadows while black areas indicate no shadow.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Raw Shadow
width45%
width10%
width45%
Render (menu) > Render Settings > Raw Shadow
width5%
width33%
