width62%
The Sampler Info Render Element is a color image that provides information about the scene, with the choice to show any of various aspects as color blocks. This render element provides information about various aspects of the shaded points such as position, normal, bump normal, reflection/refraction vectors and UVW coordinates, which previously were only available through the Extra Texture Render Element. This render element can be used either for world position passes or normal passes. It extracts particular information about the scene, converting the gathered information into RGB data for use in compositing.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Refraction glossiness
width45%
Image Added
width10%
width45%
Render (menu) > Render Settings > Refraction glossiness
Image Added
width5%
width33%
