width62%
The V-Ray Toon Render Element renders the entire scene with the  V-Ray Toon rendering effect and contains a mask for the toon outlines, although the toon color is not present in it. It also supports opacity set from the toon effect, presenting it as grayed outlines.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Refraction glossiness
width45%
Image Added
width10%
width45%
Render (menu) > Render Settings > Refraction glossiness
Image Added
width5%
width33%
