width62%
The Shadow Render Element is a color image that works as a reverse mask for shadows and can be used to lighten, darken or tint shadows. Shadows can be lightened in the composite by adding this pass, or darkened by subtracting this render pass from the final composite.
The VRayShadows render element is the product of multiplying the vrayRE_Raw_Shadow Render Element with the vrayRE_Diffuse Render Element in the composite.
UI Text Box
typenote
Specific objects can be excluded from this Render Element by disabling the Generate Render Elements option in the VRayObjectProperties node for the selected object(s).
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Refraction glossinessShadow
width45%
width10%
width45%
Render (menu) > Render Settings > Refraction glossinessShadow
width5%
width33%
UI Path
Attributes
width62%
Enabled – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.shadow.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color mapping rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
width5%
width33%
