Render (menu) > Render Settings > Shadow
Image Removed
Image Added
width62%
The Shadow Render Element is a color image that works as a reverse mask for shadows and can be used to lighten, darken or tint shadows. Shadows can be lightened in the composite by adding this pass, or darkened by subtracting this render pass from the final composite.
The VRayShadows render element is the product of multiplying the vrayRE_Raw_Shadow Render Element with the vrayRE_Diffuse Render Element in the composite.
UI Text Box
typenote
Specific objects can be excluded from this Render Element by disabling the Generate Render Elements option in the VRayObjectProperties node for the selected object(s).
||Display Render Settings button||> Render Elements tab > Shadow
Image Removed
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Shadow
width45%
width10%
width45%
width5%
width33%
