Render (menu) > Render Settings Toon
Image Removed
Image Added
width62%
The V-Ray Toon Render Element renders the entire scene with the  V-Ray Toon rendering effect and contains a mask for the toon outlines, although the toon color is not present in it. It also supports opacity set from the toon effect, presenting it as grayed outlines.
||Display Render Settings button||> Render Elements tab Toon
Image Removed
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Toon
width45%
width10%
width45%
width5%
width33%
