UI Expand
titleUI Path: Create menu > V-Ray > Import proxy
width10%
width35%40%
 Image Added
width10%5%
width35%
||V-Ray Shelf|| > Import VRay proxy
width10%
UI Text Box
typetip
A VRayProxy object can also be created by dragging and dropping a .vrmesh or .abc file directly in your active viewport.
