width62%
The attributes in this section affect V-Ray subdivision and can be added to any polygonal mesh object.
UI Text Box
typetip
Since V-Ray Next, Update 2 V-Ray subdivision preserves edge and vertex creases. Compared to using OpenSubdiv, V-Ray subdivision renders faster and requires less memory.
UI Path:
||Select mesh|| > Attribute Editor > Attributes menu > VRay > Subdivision
width5%
width33%
Subdivision Attributes
