This page provides information on the User Attributes set that can be added to meshes.
width62%
Allows the user to specify their own attributes, which can then be accessed with
the User-defined Color Map (VRayUserColor)
 and User-defined Scalar Map (VRayUserScalar)
ui-expand
 textures to provide per-object values for shading attributes. They can also be used in the file name of File nodes to resolve the bitmap file name on a per-object basis. Several attributes can be specified in the string, separated with a semicolon ';' character. User attributes can also be specified on transform nodes. The final string of user attributes for a given object is a concatenation of the user attributes specified on the shape of the object and the user attributes specified on its parent nodes along the DAG path. This allows to conveniently add attributes to a large part of the DAG hierarchy.
UI Text Box
typeinfo
Starting with V-Ray 5.0, when user attributes are used in the beginning of a file path, V-Ray treats the path as absolute. For example, if a file node loads a texture from <userAttribute>/texture.png, the path is treated as absolute and the Maya project path will no longer be prepended.
title
UI Path: ||Select mesh|| > Attribute Editor > Attributes menu > VRay > User Attributes
width5%
width33%
Image Modified
User Attributes
width62%
User attributes – A list of attributes separated by semicolons that are assigned to the mesh.
Expand
titleScripting
UI Text Box
typeinfo
 Add to node:
vray addAttributesFromGroup "pSphereShape1" "vray_user_attributes" 1;
Attributes:
vrayUserAttributes
width5%
width33%
