width62%
User attributes – A list of attributes separated by semicolons that are assigned to the mesh.
Expand
titleScripting
UI Text Box
typeinfo
 Add to node:
vray addAttributesFromGroup "pSphereShape1" "vray_user_attributes" 1;
Attributes:
vrayUserAttributes
width5%
width33%
Animated User Attributes
If you need to animate the value of a user attribute, you can create a custom dynamic attribute attached to the shape or transform of an object, and animate that. The dynamic attribute must be named vrayUserColor_attrName or vrayUserScalar_attrName or vrayUserString_attrName depending on the attribute type. You can then use the tag <attrName> in textures like VRayUserColor and VRayUserScalar as well as the file name of a File node.
