This page provides an outline of the different methods for using materials in V-Ray for Unreal.
Floatingpagetoc
Section | |||||||||||||||
Native Unreal Materials and Material Instances
V-Ray for Unreal supports the native Unreal Materials with complex shader graphs and Material Instances. For more details see the Unreal Materials and Material Instances documentation.
V-Ray Material Instance Asset
The V-Ray Material Instance Asset is a material asset that enables you to easily create V-Ray materials in Unreal. For more details see the V-Ray Material Instance Asset documentation.
Render material from .vrscene
This feature allows you to switch between rendering the material that was set in Unreal Engine or the material that was stored in the .vrscene file
For more details see the Render material from.vrscene documentation.
External Material Libraries
If you would like to use a material that is not yet supported, you can take advantage of the functionality to map Unreal materials to V-Ray materials created with another V-Ray plugin
. For more details see the External Material Libraries documentation.
