The Raw Refraction Render Element is a color image that stores refraction information calculated from materials' refraction values in the scene. Surfaces with no refraction values set in their materials will contain no information in the render element and therefore will render as black.
To properly calculate the Raw Refraction Render Element, the Refraction Render Element must also be added to the list of render elements being calculated during the rendering process to properly determine all the refraction information in the scene.
UI Expand
title
UI Path: ||Display Render Settings button|| > Render Elements tab > Raw Refraction
Image Modified
To use render elements, select from the Available render elements column and click the Add button to add the passes you wish to generate at render time. When you render the scene, the added render elements listed in the column on the right, will also render, which can be viewed from the VFB window's channel drop-down menu.
For more information on the parameters on this dialog, see the Render Elements tab page.
