This page provides information on Cameras and Camera Settings in V-Ray for Unreal.
Floatingpagetoc
width50%
V-Ray for Unreal works with standard Unreal cameras and Viewports. However, the standard cameras do not provide exposure control. To use exposure control and other real-world camera settings, it is recommended to use the VRayPhysicalCamera Blueprint Actor.
width5%
width45%
UI Text Box
typewarning
The exposure and color corrections do not work as a global PostProcess volume and are individual per camera. To see the changes you make to the VRayPhysicalCamera's settings in the viewport you have to look through the camera itself.
Expand
titleClick here to expand for screenshots of the settings...
width10%
width80%
width10%
UI Paths
width50%
The VRayPhysicalCamera actor is accessible through the Modes > V-Ray Assets > VRayPhysicalCamera. Select the Blueprint and drag and drop it in the level.
 ||Modes Tab|| > V-Ray Assets VRayPhysicalCamera
width5%
width45%
Camera Settings
The VRayPhysicalCamera is based on the Unreal Camera, therefore all features are present and accessible but only some are supported in the current version. When rendering with V-Ray the following parameters are supported:
Current Camera Settings
width50%
Filmback Settings
Sensor Width – Specifies the horizontal size of the film gate in millimeters.
Sensor Height – Specifies the vertical size of the film gate in millimeters.
Focus Settings
Focus Method – Specifies if Depth of Field (DoF) is applied to the camera. None means no DoF is applied. When Manual is selected, the DoF is controlled by the Manual Focus Distance and F-number parameters.
Manual Focus Distance – Specifies the distance at which objects are in focus.
Current Focal Length – Specifies the equivalent focal length of the camera lens in millimeters.
UI Text Box
typetip
You can use Unreal's PostProcess effects in the Color Grading, Film, Lens categories such as Bloom, Lens Flares, Chromatic Aberations , etc. to modify the feel and look of the camera shot. Please note that Unreal's tonemapper and PosProcess effects will be enabled when looking through the VRayPhysicalCamera and Enable Viewport Rendering is On, or when using Unreal's Camera or CineCamera actor.
width5%
width45%
 VRay Physical Camera Settings
width50%
Exposure
Enable ExposureEnables V-Ray exposure control. When enabled, the F-number, Shutter Speed ^-1, and Film Speed (ISO) settings will affect the image brightness.  If enabled, Unreal's tonemapper and PostProcess effects will be disabled when looking through the camera and Enable Viewport Rendering is On .
3ds Max Compatible – Enables 3ds Max compatible exposure control. Enable Exposure must also be checked for 3ds Max exposure to work.
Film Speed (ISO) – Determines the film sensitivity. Smaller values make the image darker, while larger values make it brighter.
Shutter Speed S^-1 – Specifies the shutter speed, in inverse seconds, for the still photographic camera. For example, shutter speed of 1/30 s corresponds to a value of 30 for this parameter.
F-number – Determines the width of the camera aperture and, indirectly, exposure. If the Enable Exposure option is checked, changing the F-number will affect the image brightness. If Focus Method is set to Manual or Tracking, F-number will control the strength of the DoF. Low values will produce a strong DoF effect and high values will produce little DoF.
UI Text Box
typetip
When adjusting F-number for desired DoF effect you need to compensate the exposure with either ISO or Shutter Speed S^-1 values.
White Balance – Allows additional modification of the image output. Objects in the scene that have the specified color will appear white in the image. Note that only the color hue is taken into consideration; the brightness of the color is ignored.
Reinhard Burn Value - Specifies the multiplier applied to bright colors.
Distortion
Distortion Type – Specifies how the distortion is determined.
Quadratic – Distortion is increased as the square of distance from the center. The default distortion type. It uses a simplified formula that is easier to calculate than the Cubic method.
Cubic
 – Distortion is increased as the cube of distance from the center.
Amount – Specifies the distortion coefficient for the camera lens when the Distortion type is set to either Quadratic or Cubic. A value of 0.0 means no distortion; positive values produce "barrel" distortion, while negative values produce "pillow" distortion.
Clipping
(plus) NEW -  Near Clip Plane – Specifies the offset from the camera (in cm) of the clipping plane. Geometry before this range will be clipped and will not be rendered.
UI Text Box
typenote
Effect of Near Clip Plane will not visible in the viewport in UE 4.21.2.
width5%
width45%
Examples
width10%
width35%
F-number
(Film Speed(ISO)=100; Shutter Speed=100; White Balance= (1,1,1) )
Image slider
minLabel1.4
maxLabel8
Panel
borderStylenone
F-number = 1.4
Panel
borderStylenone
F-number = 4
Panel
borderStylenone
F-number =8
width10%
width35%
White Balance
(Film Speed(ISO)=100; Shutter Speed=100; F-number =1.4)
Image slider
minLabelNeutral
maxLabelWarm
Panel
borderStylenone
Panel
borderStylenone
White Balance= (1,0.7,0.6)
Panel
borderStylenone
White Balance=(0.7,0.8,1)
width10%
