This page provides information on the Raw Lighting Render Element.
Attributes
Common uses
The Raw Lighting Render Element is useful for changing the appearance of direct lighting after rendering in a compositing or image editing software. Below are a couple of examples of its use. In this set of render elements, direct lighting affects the back of the alien figure the most due to a strong back-light in the scene as well as the top of the circular machine above the figure.
Underlying Compositing Equation
vrayRE_Raw_Light x vrayRE_Diffuse = vrayRE_Lighting
