This page gives some basic details about the Refraction Filter Render Element and how it is used in compositing.
width62%
The Refraction Filter Render Element is an image that stores refraction information calculated from the materials' refraction values in the scene. Materials with no refraction values appear as black, while refractive materials appear as white (maximum refraction) or gray (lesser amounts of refraction). If any hue (color) is specified in the material's Refractive Color parameter, that hue and value will be represented here in the Refraction Filter as well as being affected by the refraction's Amount parameter.
In comparison, the Raw Refraction Render Element (vrayRE_Raw_Refraction) is a color render element that takes materials and their colors into account when rendering refraction. Multiplying these two render elements together produces the Refraction Render Element (vrayRE_Refraction).
UI Text Box
typenote
 To properly calculate the Refraction Filter Render Element, the Refraction Render Element must also be added to the list of render elements being calculated during the rendering process to properly determine all the refraction information in the scene.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Refraction Filter
width5%
width33%
Attributes
width62%
Enabled – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.refractionFilter.vrimg).
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
width5%
width33%
Common Uses
The Refraction Filter Render Element is useful for changing the appearance of refractive elements after rendering, using a compositing or image editing application. Below are examples of possible uses.
width10%
width40%
width40%
Original Beauty Composite
width10%
width10%
width40%
Refraction Filter Render Element with added contrast
width40%
Tinted Refraction Filter Render Element with added contrast
width10%
width10%
width40%
Refractions with added contrast
width40%
Tinted Refractions with added contrast
width10%
Underlying Compositing Equation
The Refraction Filter Render Element is multiplied by the Raw Refraction to produce the same information seen in the Refraction pass, but having them separated out allows them to be manipulated individually before combining them together.
vrayRE_Raw_Refraction x vrayRE_Refraction_Filter = vrayRE_Refraction
Fancy Bullets
typecircle
  • To properly calculate the refraction information in the Refraction Filter and Raw Refraction Render Elements, the Refraction Render Element must also be rendered at the same time, even if it's not going to be used in the compositing process. Doing so enables all the refraction information to be included in the rendering calculations.
