V-Ray for Houdini
V-Ray for Houdini Help
Tutorials
Old Version
15
changes.mady.by.user
Gergana Lilkova
Saved on
Jul 10, 2020
compared with
New Version
16
Kristin Ivanova
Saved on
Jul 10, 2020
Previous Change: Difference between versions 14 and 15
Next Change: Difference between versions 16 and 17
View Page History
This line was added.
This line was removed.
Formatting was changed.
Thumbnailspagesettings
ThumbnailOverlayRectangleColour
0,0,0
ThumbnailBGImageHeight
250px
280px
ThumbnailSubTextSize
12px
ThumbnailTextColour
White
ThumbnailTitleTextSize
22px
ThumbnailOverlayRectangleHeight
45%
50%
ThumbnailOverlayRectangleBottomPadding
10px
Workflow Tutorials
width
2%
4%
width
32%
20%
Thumbnail
ThumbnailTitleText
Material Presets in V-Ray for Houdini
ThumbnailBGImage
ThumbnailSubText
Information about the Material Presets in V-Ray for Houdini
ThumbnailPageLink
https://docs.chaosgroup.com/display/VRAYHOUDINI/Material+Presets+in+V-Ray+for+Houdini
width
4%
width
32%
20%
Thumbnail
ThumbnailTitleText
Adding Displacement to Object
ThumbnailBGImage
ThumbnailSubText
How to set displacement to an object.
ThumbnailPageLink
https://docs.chaosgroup.com/display/VRAYHOUDINI/Adding+Displacement+to+Object
width
4%
width
32%
20%
Thumbnail
ThumbnailTitleText
Custom Data as UV Coordinates
ThumbnailBGImage
ThumbnailSubText
How to set custom data as UVs in V-Ray for Houdini
ThumbnailPageLink
https://docs.chaosgroup.com/display/VRAYHOUDINI/Custom+Data+as+UV+Coordinates
width
2%
4%
section
width
2%
width
32%
20%
Thumbnail
ThumbnailTitleText
Fog and Environment Fog
ThumbnailBGImage
ThumbnailSubText
Fog and Environment Fog creation in V-Ray for Houdini
ThumbnailPageLink
https://docs.chaosgroup.com/display/VRAYHOUDINI/Fog+and+Environment+Fog
width
4%
width
20%
Thumbnail
ThumbnailTitleText
Projection Baking with V-Ray
ThumbnailBGImage
ThumbnailSubText
Step-by-step tutorial showing how to use V-Ray BakerTool or V-Ray Renderer ROP for projection baking.
ThumbnailPageLink
https://docs.chaosgroup.com/display/VRAYHOUDINI/Projection+Baking+with+V-Ray
width
4%
width
20%
width
4%
width
32%
20%
width
32%
4%
width
2%
20%
V-Ray and Render Farm Managers
width
2%
4%
width
32%
20%
Thumbnail
ThumbnailTitleText
HQueue and V-Ray
ThumbnailBGImage
ThumbnailSubText
How to set up a render farm using HQueue and V-Ray
ThumbnailPageLink
https://docs.chaosgroup.com/display/VRAYHOUDINI/HQueue+and+V-Ray
width
4%
width
20%
width
4%
width
32%
20%
width
32%
4%
width
2%
20%
