Official release
Date – July 21, 2016
Download – Build 3.40.03
Bug Fixes
V-Ray
Fancy Bullets
typecircle
  • Fixed image sequences with an index out of the sequence range not rendering
  • Fixed crashes on old Maya versions on virtual machines and old GPUs
  • Fixed wrong result with material environment override
  • Fixed set driven keys not being exported correctly in some cases
  • Fixed export of textures with multibyte character names
  • Fixed outline appearing in the Matte shadow render element with certain sampler settings
  • Environment overrides now have textured previews in viewport 2.0
V-Ray IPR
Fancy Bullets
typecircle
  • Changes to the Rounded Edges' corners parameter were not detected
VRayProxy
Fancy Bullets
typecircle
  • Fixed wrong animation range in the UI
  • Fixed mesh visibility lists not working after scene reload
VRayDisplacement
Fancy Bullets
typecircle
  • Fixed issues with Ptex and vector displacement
VRayDirt
Fancy Bullets
typecircle
  • Fixed UI issue with locked subdivs when "Use local subdivs" is disabled
VRayTriplanar
Fancy Bullets
typecircle
  • Fixed different texture instances sharing the same UI control
VRayIESLight
Fancy Bullets
typecircle
  • Fixed crash when toggling the target
VRayRectLight
Fancy Bullets
typecircle
  • Fixed high CPU usage in Viewport 2.0
PartIO
Fancy Bullets
typecircle
  • Fixed crash with PTC files and rgbPP expression
VRayLightSelect
Fancy Bullets
typecircle
  • Now works with probabilistic lighting
VRayDenoiser
Fancy Bullets
typecircle
  • The denoiser update button did not work after aborting denoise
VRayObjectProperties
Fancy Bullets
typecircle
  • Fixed issues with objects with identical names
XGen
Fancy Bullets
typecircle
  • Fixed crash when rendering archive
