UI Text Box
sizemedium
typetip
V-Ray 5 introduces a new and improved VRayProxy node that's simpler, faster and offers new and powerful features.
Scenes can be easily converted to the new VRayProxy with the built-int converter found in the V-Ray menu > Tools > Convert to New V-Ray Proxy Node.
UI Expand
titleUI Path: Create menu > V-Ray > Import proxy
width10%
width50%
width5%
width25%
||V-Ray Shelf|| > Import VRay proxy
width10%
UI Text Box
typetip
A VRayProxy object can also be created by dragging and dropping a .vrmesh or .abc file directly in your active viewport.
