This page describes how to import a mesh into the V-Ray Proxy attributes in Maya using the old V-Ray proxy node.
The proxy import process creates a VRayMesh node which imports geometry from a V-Ray Proxy loads geometry for rendering from file on disk. The node can load V-Ray proxy (.vrmesh) and Alembic (.abc) files. After After loading the file, the V-Ray proxy is imported, its parameters appear Proxy attributes are accessible in the Attribute Editor.
To see how to import a load files with V-Ray Proxy, see the Import V-Ray Proxy using the "vrayCreateProxy" command, please refer to Scripting page.
UI Text Box | ||||
V-Ray 5 introduces a new and improved VRayProxy node that's simpler, faster and offers new and powerful features. Scenes can be easily converted to the new VRayProxy with the built-int converter found in the V-Ray menu > Tools > Convert to New V-Ray Proxy Node. |
Basic Parameters
Section | ||||||||||||||||||||||||||||||
Import V-Ray Proxy
This dialog sets basic import parameters and creates the VRayProxy node.
Section | |||||||||||||||||||||||||||||||||||
UI Text Box | ||
To use the new VRayProxy, enable the Use the new VRayProxy node options upon import. To convert an old proxy mesh to new, go to V-Ray menu > Tools > Convert to New VRayProxy Node. |
VRayProxy Attributes
These parameters appear in the Attribute Editor after the VRayProxy node has been created and the mesh has been imported.
Basic Parameters
Alembic Layers
This rollout becomes active only if the loaded proxy file is in .abc file format.
Anchor proxyAnimationParams proxyAnimationParams
Animation Parameters
Restore the Mesh
Visibility Lists
Anchor | ||||
Alembic Proxy Parameters
Point Cloud
Material assignment overrides
UI Text Box | ||
The material assignment overrides is still a highly experimental feature and can change at any point! |
VRayMesh File Info
