Fancy Bullets | ||
The V-Ray Standalone tool is a command-line rendering tool supporting V-Ray's native .vrscene file format. Location:Start Menu\Programs\Chaos Group\V-Ray for Rhinoceros\V-Ray standalone command prompt This is a command-line utility that can be used to convert .vrimg image files to .exr files in OpenEXR format. A command-line utility that utility that can be used to denoise still images or animations outside of Rhino. This can be especially useful for animated sequences because the standalone tool can look at multiple frames at once and produce a better denoising result. A command-line utility that lists V-Ray plugins and detailed description for them. |
GI Tools and Utilities
Fancy Bullets | ||
The irradiance map viewer can be used to view, merge and save irradiance map files created by V-Ray. |
