The Refraction Filter Render Element is an image that stores refraction information calculated from the materials' refraction values refraction values in the scene. Materials with no refraction values appear as black, while refractive materials appear as white (maximum refraction) or gray (lesser amounts of refraction). If any hue (color) is specified in the material's Refractive Color parameter, that hue and value will be represented here in the Refraction Filter as well as being affected by the refraction's Amount parameter.
In comparison, the Raw Refraction Render Element is a color render element that takes materials and their colors into account when rendering refraction. Multiplying these two render elements together produces the Refraction Render Element.
UI Text Box
type
note
To properly calculate the Refraction Filter Render Element, the Refraction Render Element must also be added to the list of render elements being calculated during the rendering process to properly determine all the refraction information in the scene.
width
5%
column
width
45%
Image Removed
UI Path
: ||out Network||> V-Ray Render Elementsnode
> V-Ray > Render Channel >
V-Ray Color Channel (RE)> Type > Refraction Filter
width
5%
width
45%
Image Added
Attributes
width
50%
The parameters for this render element appear in the V-Ray RenderChannelColor render channels node.
Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – When enabled, the Color Mapping options in the render settings will be applied to the current render channel.
Consider For AA– Consider for Anti-Aliasing – When enabled, anti-aliasing will be used where possible.
Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler tab of the Sampler tab of theV-Ray Renderer node.Color Mapping – When enabled, the Color Mapping options in the render settings will be applied to the current render channel
VFB Color Corrections – Applies the post render color adjustments made from the VFB.
